Shelly's go offline. New modem/router?
  • Hi all,
    Our Shelly's go offline regularly.
    Solution could be: fixed IP-address.
    However, each time we try to set a fixed IP-address, the Shelly goes offline forever.
    Maybe the solution is to install a new modem/router.
    Is there a list of modem/routers that are recommended by Shelly?
    Just curious: Why is it that my cheap Aliexpress smart devices never have problems with setup and reliability and Shelly's do?
  • Hej Elsdeniep
    If your Shellies go offline after setting a fixed IP, the router maybe set up in a way it doesn't accept fixed IPs. So possibly you don't need a new router but should check the router - setup.
    And to your question: possibly you don't see the problems Alibaba - users have, because there's no forum. After many years of Alibaba and now about 450 Shellies in the last 1,5 years my choice is absolutely Shelly.
  • However, each time we try to set a fixed IP-address, the Shelly goes offline forever
    Sorry, you do something wrong. My >120 shelly all work with static IP!
    Yes in our lexicon or link in the "tipsfor beginners".
  • Hej Elsdeniep
    MarkusSorger thank you for your opinion.
    In Holland, I have a Ziggo modem.router with Puma7 chipset :/.
    The setup can hardly be changed (DHCP settings, etc.)
    I want to bridge the Ziggo modem and create a VLAN in a better manageable router.
    Do you think that is a good idea?
    I really like the Shelly concept, but in my experience we do not come across installation and connectivity problems with other devices. Our Shelly's demand more problem solving.
    For that reason I am looking to create a better setup.
  • @66er thank you for your reply.
    I am pretty confident that we follow the instructions correctly.
    We have a Puma7 chipset modem/router. Could that be the cause of the issues?
    I have found the Erste Hilfe Koffer.
    Dort finde ich nur Modems die nicht kompatibel sind.
    Gibt es auch eine Liste mit modems die besonders geeignet sind fuer Shelly?
    Gruesse,
    Els
