Shelly Pro EM - Daily Energy Monitoring
Hinweis für Entwickler
  • Hi,
    I purchased a Shelly Plus 1 EM to monitor the daily usage of an appliance and to trigger a notification if the appliance used more than some many KW in a day. I did this with using the following (it's not the complete script - just the bit relevant to this thread) :-
    Let startMonitor = True
    Let maxEnergy = 4000000
    Let eAccumulator = 0
    Shelly.addStatusHandler(function (event, user_data) {
    print(JSON.stringify(event));
    if (typeof event.delta.aenergy !== "undefined") {
    print (startMonitor);
    print(JSON.stringify(event.delta.aenergy["by_minute"]));
    if (startMonitor) {
    eAccumulator = eAccumulator + event.delta.aenergy.by_minute[0];
    print (eAccumulator = eAccumulator + event.delta.aenergy.by_minute[0]);
    if (eAccumulator > maxEnergy) {
    print(eAccumulator, "4Kw used consumed");.....................................
    I've now brought a Shelly Pro EM and would like to do the same for each of the Clamps for the circuits they are monitoring. I know I need to split the Clamp data in my script. However my issue is what values / variable to monitor. This there a similar value / variable like event.delta.aenergy["by_minute"] I can use with the Shelly Pro EM?
    Please note I'm a complete beginner to this and finding this scripting language hard to grasp. So I hope the above makes some sense.
    TIA
