Interference/ Cross talk on the Cloud/Smart Control
  • Hi.
    I've been experimenting with a couple of Shelly Uni and a Plus Uni and found something strange that looked like cross talk between the system. My first Uni is on a breadboard with the inputs connected to the outputs crossed so that I can check the function on the app. The inputs are separated from the relays so the relays can only be activated by the app. I have a scene programmed so that I get a phone notification in case one of the inputs is maintained on for more than 10 seconds. This works as it should and I'm ready to implement the board into the intended application.
    Yesterday I registered a Shelly Uni and a Plus Uni to a different room and this time "cross" connected the different Shelly's outputs with the other's inputs, again to see the operation on the app. Again, I separated the inputs from the relay outputs and on the Plus Uni I programmed a scene where if the input is activated for more than 5 seconds, it will activate the output for 1 seconds. To test this, I use Shelly Uni number 3 to change the inputs on the Plus Uni. There are no phone notification scenes on this pair of Shellies
    Now the strange situation I discovered. While cycling through the actions to see the behavior of these 2 Shellies, on 2 separate occasions, I received a phone notification from the first Shelly in the post that is physically separated from these 2 and on a separate room in the App. and I did not change anything to receive the phone notification.
    Is this "problem" normal?
