Shelly Script: reading input at startup
Hinweis für Entwickler
  • How can I read the input state at startup of the Shelly script?
    let resultx = null;
    Shelly.call("Input.GetStatus", {id:0},
    function(result) {
    print("Status:", result.state); resultx = result;
    print("out: ", resultx);
    Log:
    out: null
    Status: true
    The print "out" is executed before the print "status".
    How can I get the status of the input after calling Shelly.call("Input.GetStatus"...
    BR, Harald
  • Thanks to Tomasz Brzozowski @ Facebook:
    Shelly.call is an asynchronous function. Use Shelly.getComponentStatus - synchronous call.
    This works now:
    inputstate = Shelly.getComponentStatus("input:0").state
