How use cURL command in Shelly script
Hinweis für Entwickler
  • I have Alliance-Apps OpenDTU and it support cURL command. I hope that I can control this product using Shelly script. How I can send cURL command usingShelly script?
    Command what I want use is:
    curl --user "user:pwd" http://192.168.x.x/api/limit/config --request POST --data "data={'serial':'1144xxxxxxxx', 'limit_type':1, 'limit_value':50}"
    I tried use code like below with my own setups, but it not work and I don't know what I must to do, Can somebody help me how to do that?
  • I am trying the same and want to sent the Limit to the opendtu und I have the same problem. Would you be so kind to share your script?
    BR
    Solaa
    Einmal editiert, zuletzt von Soolaa (27. Februar 2025 um 19:26)
  • Hello markok
    i'd like to see your solution as well. I tryed some arround, but didn't get to an result with your code and the help of the other topic.
    My goal is just to send an cURL order to openDTU to adjust the Powerlimit two times a day.
    Regards
    Shelly Anfänger, kein Script Experte, kein IT Spezialist. Bitte habt Nachsicht :)
