Share variables between scripts?
Hinweis für Entwickler
  • Hello,
    Another question
    How can I exchange variables between different scripts on the same device?
  • There are several ways to accomplish this. For instance, you could manually create events using Shelly.emitEvent("name", data); and then employ an event handler to subscripe to them in another script.
    Alternatively, you could utilize a script slot as an external text repository, or, you can leverage the Shelly KVS storage to store keys and values. Furthermore, you could utilize endpoints for communication within the Shelly, inside your network. You could even develop a small web page on an endpoint hosted locally on your Shelly.
    Here are a couple of exampels:
    Creating and using own Events:
    _[Deleted]_
    21. Februar 2024 um 10:36
    KVS as Storage Exampel:
    Script Slot as Storage Exampel:
    ostfriese
    2. Februar 2024 um 15:48
    Http Endpoints for communication Exampel:
    _[Deleted]_
    22. Januar 2024 um 20:49
    Webpage on Shellys Exampel:
    _[Deleted]_
    21. Februar 2024 um 09:54
    External storage via MQTT or UDP is also an option.
    2 Mal editiert, zuletzt von _[Deleted]_ (21. Februar 2024 um 11:28)
  • @De kat
    Thank you very much for this information, I will work through this.
    I see now there are a few options.
