Pro 4PM, need help with script that can "AND" multiple events to turn on 1 output
  • Hello,
    I have been working on a script using BLE-Shelly-Blu and BLE-Events-Handler, first time to work with this controller.
    I am able to use Shelly Blu door and window sensor to turn on/off 1 relay, but I want to use 2 or more door window sensors to activate a single relay.
    When any sensor is open, the relay energizes...works fine.
    But
    I want to have all sensors closed to de-energize the relay, I was trying to use "AND" in the condition statement but I am unable to get it working.,
    Here is the code I have been working on.
    /** SCENE START 4 - Shelly BLU Scanner example **/
    conditions: {event: "shelly-blu", address: "b0:c7:de:2c:7e:9a", window: 0} &&
    conditions: {event: "shelly-blu", address: "b0:c7:de:41:5a:5c", window: 0}
    action: function (data) {
    // prints the data parsed from Shelly blu device
    console.log("Shelly BLU device found", JSON.stringify(data));
    //toggles the first built-in relay
    Shelly.call("Switch.Set", { id: 0, on: false });
    //Shelly.call("Switch.Toggle", { id: 0 });
    /** SCENE END 4 **/
    Can anyone advise on how to combine these conditions to set the switch to OFF
    I can get one sensor to work if I comment out the && second sensor...
    Thanks in Advance,
    Jim
    Einmal editiert, zuletzt von jmanolio (19. Februar 2024 um 01:01) aus folgendem Grund: Issue was resolved with help of De kat...thanks
