automatic lighting control problem
  • I use Shelly Plus 1 relay to turn the light on when the garage door opens and turn the light off when I close the garage door. I also connected a physical switch to the Shelly Plus 1 relay.
    Relay settings: switch mode - toggle switch
    Door opening sensor: Shelly Door/Window 2
    In the scene, I set it so that it turns on the light when the door has been open for 0.5 minutes. And turn off the light if the door has been closed for 1 minute. This was necessary because of the vibration.
    My problem is that it turns off the light even when the physical switch is on. What have I done wrong? That is, when the garage door is closed, but the physical switch is on, the scene turns off the lights. Is the physical switch not dominant?
    2 Mal editiert, zuletzt von sziszkont (16. Februar 2024 um 18:26)
