How to wire roller shutters with Shelly2PM when the roller switch has 2 L inputs
  • hi everyone,
    I am trying to automate my roller shutters using Shelly2PM and am having some trouble.
    Attached is a picture of how the roller shutter is wired (without shelly). The shutter switch is gira 10x/250
    The switch take two L inputs, and one each for up and down action. Green wire is for Earth and Blue is neutral.
    I wired the shutter with the shelly as in the second pic.
    Used a 3-pin wago connector for Live, output of that wago connector goes into L of shelly and from the shelly the Live input goes into the switch.
    I did the same for neutral as well.
    For earth no additional connection was needed.
    In the beginning, it all worked fine, the shelly and the roller shutters were working as expected. Then the shutters stopped working and whenever i tried, i could only hear a click sound on the shelly when a switch was turned on/off. i'm not sure what could be the problem here?
    Two of my other windows have only one Live wire going into the switch and those were pretty easy to automate. they've been running fine so far.
    thanks
