Shelly Pro1PM The device does not respond to the script.
Hinweis für Entwickler
  • Hello everyone.
    I'm seeking help with configuring my Shelly Pro 1PM.
    I need it to count 1 kWh upon activation and then have the device turn off until the next activation.
    The problem is that the device doesn't respond to scripts at all. The script runs, the logs indicate that everything is working, but nothing happens.
    How can I make the switch follow the programmed sequence?
    Thanks for the responses!
  • Hallo Alex Graveler,
    Let us go through your question step by step:
    -->I need it to count 1 kWh upon activation and then have the device turn off until the next activation.
    Ok, you just want a script thats turns the Relay off when its reached 1kwh power, and a new input (button? or switch?) turns the relay back on?
    -->The problem is that the device doesn't respond to scripts at all. The script runs
    So you already have some kind of Script for this.
    -->How can I make the switch follow the programmed sequence?
    Without seeing your script, I will not be able to help you.
  • Hello De kat.
    Yes exactly.
    I tried to write it myself, but then I found a script for my device in the library.
    Here is it:
  • And here is my version of this, untested.
    Let me know if it works. ;)
    Apache License Version 2.0, January 2004, siehe Link für mehr Infos: https://github.com/ALLTERCO/sh…xamples/blob/main/LICENSE
    And here is a version that stores the consumption value of one session, in your local Shelly KVS memory, so it can somehow recover some lost data.
    7 Mal editiert, zuletzt von _[Deleted]_ (3. Februar 2024 um 05:05)
