Is it possible to activate alarm via http request?
  • Thank you for the answer,
    but I'm able to enable/disable shelly motion with shortcuts ( ...settings?motion_enable = true ) BUT:
    - It's not possible to use shelly cloud ( https:\\shelly...) to enable motion sensor
    - so in the shortcuts before I have to enable VPN -> home so I'm in local network and then launch the command
    - sometimes some device not risponding immediatly , so the command don't work
    If it would be possible to enable/disable shelly alarm directly from shelly cloud I could use Iphone to enable/disable alarm when i go out/go back home
  • I don't have motion to test this. But changing settings and enabling/disabling an alarm are two different things.
    Alarms are treated like scenes , I think I have already explained this in English.
    But to be on the safe side, here are the pictures again of how to do it via http post
