Monitoring SW input independently from output
  • Hello all,
    I recently purchased a WD, and directly updated it to 1.2.8. I have a switch connected to the SW input that I would like to monitor independently from the output. Therefore, I've set it to "detached" in the local web UI, but it still behaves as if it was "attached to output" (i.e. closing the switch toggles the output). In addition, the UI always reports "no action" on the input, even when the switch is closed. The only workaround I found is to set "input mode" to "disabled". In this case, the UI always reports "OFF" for the input, and its setting page doesn't allow to re-enable it anymore.
    Has anyone managed to make it work?
  • I am having a similar issue, I need the SW input to work independent from the output.
    In the webinterface of the WD I even have trouble finding the settings for the SW input. I also have FW 1.2.8 installed.
    Can you tell me how you made the settings..on the device screen or in the app? Where is it located?
