Something wrong
  • Below some errors where translation in Italian in wrong and doesn't fit the field because, in the example, if I choice English it is OK
    but if I change to Italian, the translation is wrong (ON = ACCESO) but as you can see, SPENTO doesn't fit the button.
    Other issue regards the widget on the dashboard. If you add a widget for a device with the add-on, in case of Temp, you can't see it.
