MQTT to email, or MQTT to Notification (iOS - iPhone)
Hinweis für Entwickler
  • With the kind help of people on this forum I have a great script running on my Plus2PM. I have tested it and am really happy.
    Next I need to be notified when the script has been triggered.
    I understand that there is no way to send an email, I do however have several "always-on" devices, from Raspberry PI, Linux box to a PC.
    From experience could somebody suggest the most reliable way to get a notification?
    This is the code into which I need to build the "notification".
    Thank you.
  • Hi. Can you please share your code? Do you always create a new scene, or you have a way to modify the existing scene and to send the email again?
    Thank you,
    Tomas
