3 1PM units state sets another 1PM unit on or Off
Hinweis für Entwickler
  • I need help in creating a script which will do the following
    I have 4 shelly 1PM units called A, B , C , D.
    If B, C or D, Turn On turn A on.
    If any one of B,C or D turn off and one of B,C,D are on dont turn A Off
    If any one of B,C or D turn off and B, C or D are not On turn A Off
  • Here is a script that could be used for this task. However, it is still an early version and has some early stage bugs.
    Additionally, the post is only available in German, but the description inside the script is in English.
    _[Deleted]_
    27. Januar 2024 um 20:51
    (It is unclear to me whether posts or links in the German section of this forum are available to English forum members. To ensure accessibility, I may need to start posting my content in both the English and German sections.)
    Einmal editiert, zuletzt von _[Deleted]_ (28. Januar 2024 um 19:41)
  • Here I have inserted your logic/conditions into the script for you. :)
    Remember that you still need to change the Shelly ips.
    Bitte, schön:
