I recently bought 3 Shelly 2pm plus switches to control our windows blinds. All came with 1.0.7 firmware. First one I put on use I immediately upgrade to 1.1
All was ok, except from a physical switch glitch. I have a 3way switch. Up, Down and stop positions. When I pressed down switch blinds went down. But when I pressed the up switch though nothing happened and for the blinds to go up I needed to go to the stop position(!).
The 2nd switch I installed (different blind) I forgot to upgrade to 1.1 and stayed at 1.0.7 and everything worked as was supposed to work. I replaced the first Shelly with a 3rd 2pm (also with 1.0.7) and also this one worked normally.
Anyone else experienced the same? Is there a way to downgrade to 1.0.7 officially or with home assistant?
Thanks
