Hi,
first of all, my script just should get status information about some cloud based virtual thermostates. ![]()
Because there is an other issue to get the status of just one thermostate, I get the status from all my devices with https://shelly-xx-eu.shelly.cloud/device/all_status . ![]()
This works so far, but when I want to parse the JSON data, the script crashes with OUT OF MEMORY. ![]()
I found one open issue in the forum, where the provided solution is to reduce the variables. ( see 22849-shelly-script-bricht-bei-json-parse-ab-out-of-memory-was-tun )
This is not possible for me because I do not use many variables. And there should be enough memory available.
I get following information before executiong the parse function: "ram_size": 241192, "ram_free": 97352
The JSON to be parsed is 1422 characters long, this is not an overkill I think...
So I suggest this is a bug in the parse function.
Does anyone have a hint for me? ![]()
Or does anyone know a better solution to get the status from a virtual thermostate with a smaller amount of data?
Many thanks in advance,
Schmuckerl
