Download Daten vom pro 3EM
  • Ich habe seit knapp einem Jahr einen Shelly pro 3EM im Betrieb und nun aus versehen die InfluxDB gelöscht, in die ich die Daten schreibe.
    In der Web App habe ich nun die Möglichkeit mir alle Daten vom Gerät zu holen. Hat auch wunderbar funktioniert, nur komme ich mit den Spalten nicht zurecht.
    1700092800,16.6373,16.6195,0.0000,0.0000,0.0000,4.3657,1026.8,992.7,1069.6,1034.4,229.505,228.781,229.156,4.674,4.520,4.534,0.8888,0.8957,0.0000,0.0000,0.0000,3.1135,56.1,50.3,214.0,208.9,229.915,229.167,229.539,0.932,0.911,0.919,0.8156,0.8196,0.0000,0.0000,0.0000,2.1381,51.9,44.6,161.1,153.7,230.643,230.061,230.347,0.700,0.668,0.686,0.028,0.026,0.027
    1700092860,16.6177,16.6010,0.0000,0.0000,0.0000,4.3645,1007.6,992.2,1047.5,1033.1,229.470,228.816,229.191,4.578,4.515,4.534,0.8871,0.8934,0.0000,0.0000,0.0000,3.1077,55.2,50.7,213.1,209.5,229.597,228.902,229.279,0.930,0.913,0.920,0.8150,0.8190,0.0000,0.0000,0.0000,2.1376,52.4,44.2,160.7,153.8,230.531,229.744,230.183,0.699,0.669,0.686,0.028,0.026,0.027
    1700092920,16.5462,16.5295,0.0000,0.0000,0.0000,4.3524,1000.0,987.4,1042.1,1028.7,229.262,228.421,228.726,4.559,4.504,4.519,0.8761,0.8825,0.0000,0.0000,0.0000,3.1094,54.2,48.8,212.1,209.0,229.687,229.134,229.438,0.925,0.911,0.920,0.8156,0.8196,0.0000,0.0000,0.0000,2.1370,51.6,44.0,160.9,153.9,230.307,229.719,230.061,0.700,0.670,0.687,0.028,0.026,0.027
    1700092980,16.5601,16.5422,0.0000,0.0000,0.0000,4.3518,1001.2,987.7,1041.6,1029.2,229.351,228.459,228.825,4.551,4.508,4.522,0.8490,0.8548,0.0000,0.0000,0.0000,3.1008,53.3,47.9,212.1,207.5,229.754,228.716,229.402,0.925,0.906,0.915,0.8104,0.8144,0.0000,0.0000,0.0000,2.1353,52.2,44.7,161.0,153.9,230.613,229.739,230.082,0.701,0.669,0.686,0.028,0.026,0.027
    1700093040,16.2290,16.2065,0.0000,0.0000,0.0000,4.2446,998.2,984.9,1039.3,1025.0,228.726,228.115,228.404,4.553,4.495,4.514,0.8300,0.8352,0.0000,0.0000,0.0000,3.0218,53.3,47.7,210.2,206.4,229.212,228.449,228.715,0.919,0.903,0.909,0.7948,0.7977,0.0000,0.0000,0.0000,2.0885,52.0,45.0,159.5,153.8,230.042,229.498,229.703,0.694,0.671,0.683,0.028,0.026,0.027
    1700093100,16.5370,16.5139,0.0000,0.0000,0.0000,4.3311,1001.8,988.8,1039.8,1029.3,229.249,228.482,228.863,4.542,4.504,4.517,0.8663,0.8727,0.0000,0.0000,0.0000,3.0841,56.5,47.3,213.2,206.7,229.612,228.924,229.202,0.931,0.904,0.915,0.8058,0.8098,0.0000,0.0000,0.0000,2.1306,50.8,45.4,159.1,154.4,230.212,229.662,229.910,0.692,0.673,0.683,0.028,0.026,0.027
    1700093160,16.5831,16.5595,0.0000,0.0000,0.0000,4.3415,1000.4,990.7,1040.4,1032.2,229.595,229.069,229.302,4.538,4.506,4.520,0.8709,0.8761,0.0000,0.0000,0.0000,3.0875,57.5,49.5,214.0,208.3,229.627,229.102,229.359,0.933,0.909,0.916,0.8092,0.8127,0.0000,0.0000,0.0000,2.1295,51.7,46.5,159.5,155.2,230.176,229.579,229.906,0.695,0.677,0.684,0.028,0.026,0.027
    1700093220,7.1539,7.1614,0.0000,0.0000,0.0000,4.5105,1004.3,146.9,1043.7,333.5,229.436,228.706,229.087,4.556,1.456,2.461,0.8767,0.8831,0.0000,0.0000,0.0000,3.0731,56.0,49.7,210.5,205.4,229.898,228.783,229.402,0.920,0.898,0.908,0.8381,0.8433,0.0000,0.0000,0.0000,2.1468,53.1,46.5,161.4,155.9,229.851,229.100,229.429,0.705,0.680,0.693,0.028,0.026,0.027
    1700093280,3.3586,3.3655,0.0000,0.0000,0.0000,3.7947,1429.6,146.0,1375.3,319.0,229.485,228.207,229.135,6.050,1.392,1.503,0.9384,0.9442,0.0000,0.0000,0.0000,3.0766,67.1,50.0,213.6,206.6,229.773,229.092,229.471,0.931,0.900,0.914,0.8208,0.8254,0.0000,0.0000,0.0000,2.1583,53.3,45.0,160.9,154.7,229.554,228.981,229.304,0.703,0.676,0.691,0.028,0.026,0.027
    1700093340,3.4324,3.4388,0.0000,0.0000,0.0000,3.5247,221.5,201.6,337.1,317.5,229.650,229.053,229.367,1.470,1.386,1.401,0.9194,0.9252,0.0000,0.0000,0.0000,3.0743,57.9,52.7,211.9,207.8,229.976,229.216,229.597,0.923,0.907,0.912,0.8265,0.8300,0.0000,0.0000,0.0000,2.1618,54.4,45.9,162.7,155.8,230.078,229.359,229.664,0.709,0.680,0.694,0.028,0.026,0.027
    Kann mir bitte jemand helfen, was die einzelnen Spalten beinhalten?
    Danke.
    Grüße
  • Wilkommen im Forum 🤗
    Die Suche bringt viele Ergebnisse 😎
    Ein Beispiel
    apreick
    9. März 2023 um 21:37
    Oder mal mein Filter zum Suchen
    https://shelly-forum.com/search/?q=Csv+…goryIDs%5B%5D=*
  • Leider ist das nicht das Gleiche, würde ich sagen.
    Zuerst mal wurde vergessen, die erste Zeile mit den Überschriften mit auszugeben.
    Dann fängt hier das Ganze mit dem Timecode an. Dann folgen ca. 50 weitere Spalten.
    Wie und wo wurden denn hier die Daten "geholt"?
    Beim guten alten 3EM wurde das direkt in der Shelly-Weboberfläche gemacht. Jede Phase für sich.
    Datum Zeit, Energie vorwärts und rückwärts. Monate waren und sind wild gemischt. Beginnt bei mir im Dezember 23 und endet im Juni 23. Alles andere gemischt dazwischen.
    Beim TE steht aller Müll drinnen, den keiner braucht. Wahrscheinlich der komplette Unsinn, wie er auch in der App zu sehen ist. Min, Max, Durchschnitt, teuer, billig und das von allen Messgrößen. Da muss man mal mit der App ein paar Zahlen vergleiche, dann bekommt man das mit Excel schon in eine Tabelle. Kann man auch dann ein wenig minimieren.
  • ich mach ja schon 8)
    ein mal komplett und ein mal 10Tage
    dauert wohl etwas
  • also der für 10 Tage kommet mit der ersten Zeile 8)
    da ist also die Zuordnung
