Replacing a Lutron Home lighting system
  • I'm attempting to establish if it's possible to replace an entire Lutron lighting system with Shelly devices to control many, many bulbs, an RGB fibre optic ceiling, window and door blinds, and use the existing iPad mini integrated into the wall to show a Shelly dashboard and use the numerous light up wall switch clusters to control Shelly lighting scenes.
    Reasons for considering ditching the Lutron system:
    1. Requires a call out from a technician for any configuration changes + special software
    2. Current config is corrupt so can't do any changes (i'm told) and needs to be reprogrammed but nobody has a backup(!)
    3. All halogen based system, transformers and drivers are not LED friendly, and there's a lot, I'm told they all need to be replaced to use LED power.
    4. No way to integrate with Alexa for voice control in a wet environment (swimming pool)
    Searching the forum I don't see any posts mentioning "Lutron" so imagine it's an unusual project to attempt. I'll update here as I go if it's of interest for anybody else.
