shelly BLU door "rotation" is not working properly
  • I have a shelly BLU door/window beacon. the listening to the BC is working fine. I get all parameters like battery, open/close/ illumination/button
    Also rotation w tag = 0x3F is received. But the numbers are mostly 0,. after some minutes it sometimes show a value !=0 and then next packages it goes back to 0.
    I tried all positions, flat, inverse flat, on all 4 sides. it mostly returns 3F0000. = rotation = 0
    is this a bug?
    Karl
  • Works fine for me. Try updating your Blue D/W FW.
  • I do get data, and i have the latest firmware. BUT the values of rotate are not stable.
    It looks like when an open/close event happens the rotation value is always 0.
    when I let it sit the values are stable +-0.3º
    Einmal editiert, zuletzt von kw123 (15. Januar 2024 um 15:40)
  • Using four of them, I cannot confirm this behavior. Generally, they tend to send the correct level during open and close events. However, a recurring issue arises where they often send 0.1 instead of 0.
    This becomes quite bothersome as it disrupts the app's open-close state, consistently showing the 0.1 level state. While it's not precisely the same behavior, there is certainly an issue with the transition between 0 and 0.1 rotation lvl.
  • I guess I figured it out:
    if open/close value has changed and packedId has changed: ignore the rotation value. it is always 0
    so only use rotation value if no open/close event
    Karl
