shelly 1 connection driving me crazy
  • I recently bought some shelly 1
    I already installed 1 of them and its working fine using this wiring diagram 195-ar768-ausschaltung-pngI am trying to install another one following same wiring diagram but its not working
    I have a socket just beneath with L and N the L goes up to the switch box and the N goes up to the switch box and then to the lamps
    I took a connection from the N and connected it to the shelly and there is already a connection from L to the switch box so i take a bridge from it
    I tried changing it with another one also same, it doesnt work at all.
    when connected I can measure 220v between 0 and 1 terminals
    shelly ap is online and i can connect to it, when i try to toggle the switch on and off the lamp doesnt work.
    I checked all connection with multi meter continuity test all are fine so all wires are where they are supposed to be connected
    when i take the wire connected to 0 and put it back in my normal switch the lamp works fine
    its driving me crazy really just spent all day trying to make it work, the first one installed in a breeze
    anyone has any hints?
    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    I know wiring looks crap please dont laugh ^^ I just saw it today, I will call an electrician to sort it out.
    Thank you in advance
