5*Shelly H&T broken sensors(or 15)?
  • Hi all,
    In Finland we have this thing called Winter. And it surprised us again, just like every year before.
    It surprised some of our sensors too.
    Temperature outside has gone down to about -20 celsius, so it removes humidity from air.
    Images included from grafana, storing logs of 20 sensors in total for about a year now. Five of our H&T-sensors that we have been using are now showing zero percent humidity and I'm really having thought about trusting these values.
    All images have temperature displayed in green and humidity with yellow.
    I also did a spot test today (3.1.2024 1500) with Shelly H&T Plus, got ~20.5'C and 8%. Just to get another spot reading without knowing how calibrated that one is. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    one has interesting humidity
    These are installed in different rooms that are used daily as offices. All these use USB-power supply. We have no reported blackouts on the grid.
    I assume that I would have noticed 8% change when testing these.
    Do these sensors drift, or what should I make out of all this?
    Did I miss some notes about calibration or should I think that sensors require replacement?
    Your thoughts appreciated,
  • And without touching one of sensors it seems to have stabiliized a bit.
  • jujo_am 26. Januar 2024 um 16:40
    Hat den Titel des Themas von „5*Shelly H&T broken sensors?“ zu „5*Shelly H&T broken sensors(or 15)?“ geändert.
  • Now fifteen sensors have shown humidity of 0% or 100% without reason.
    In touch with service desk. Asked to factory reset devices, but it didn't yet resolve problem on sensor that I tried it.
  • Hello to Suomi,
    I know the Suomi winter from my Business trips to Oulo, Jyväskylä, Tampere, Salo, etc.
    Yes, it can be cold there....
    But you will be not happy in future, in the same way as I was, that every one-two years, the outside used HT's will die.
    They are, so it seems not developed to be used outside over a longer periode.
    I have had the same senario, that my HT which are outdoor in use, die from time to time.
    There is NO solution for this product. I have had the same, that 100% of humidity shown all the time...
    Meanwhile I changed from the outdoor used HT, to an Shelly1 with an AddOn Module and a temperatur/humidity sensor.
    Here is also important, that only the so called. DHT21 works with - 0 degrees.
    I can after testing different DHT22 and others only recomment the AM2301A from ASAIR.
    After 4 weeks now it works also in colder conditions here in South-Germany.
    But I have so far no longtime usage about the new scenario.
    So you can by in average every two years a new HT, or invest the money for an shelly plus 1 and a AddOn module + an AM2301A
    BR
    Jochen
    In Betrieb :9xShelly1, 3xShelly 2.5, 3xShellyplus2PM, 8xShelly HT, 6xShelly Plug S, 2xShelly 1PM, 3xShelly Plug, 7xShelly Button1, 1xShelly TRV, 2xShelly H&T Plus, 1xShelly1 plus mit AddOn Modul, 2xShelly Flood
    Als Spare: Shelly2.5, Shelly 1, Shelly1PM, ShellyPlugS, ShellyH&T, ShellyPlug, Shelly1plus, Shelly1PM plus, AddOn Modul
    Addons: Smarthome via Openhab 5..1.3-1@Raspberry PI 5, Backup PI 4, DEV mit PI 4, 8x TP-Link HS110, Broadlink RM4mini, ASAIR AM2301A, HA PI4, 2 x MyStrom Button
  • Thanks Scheuerer for the comment,
    Today, it was -19'C again on my very frosty walk to work. There is a river nearby, so sometimes nice looking vapor clouds rise from warmer water to the air. Cold weather and snow make nature look very nice, but it's not meant for unprotected sensors or people. :-) :-(
    However, in this case, we have no HT's directly outside. About 13 are in warehouse or office environments and rest six are in more requiring one. (usually staying under 40'C and over 25%RH at least by their sensor values)
    I had one sensor gone bad just like ones here (RH jumps from 0 to 100 and back randomly or stucks to 100), but that was ruled out of this thread, because it was highly probable to have been caused by water damage from condensation. New one has a different location and better protection against it.
    If the sensor element were a serviceable component, it would be a different story. However, having to throw away 15-20 sensors every few years doesn’t sound ideal.
    I've now had some contact with customer support, but they seem very limited in their time, so I have had no luck with getting anything that would resolve this. I’ll still give them chances to recommend something to resolve this problem, as they may be best equipped to know their sensors.
    If nothing then, maybe I need to revisit some of my old projects with AM2321 and BME280. I remember some years back reading a lot of comparisons when I was into sensors.
    If I need to get involved, i'll probably try ESP8266-01 with a sensor like one you recommended.
    But now I'll just work to get tickets done. Maybe one of the broken sensors could be disassembled and put under an expensive microscope. (to get some payback for the all time invested already. ;))
    BR,
    am
