Shelly PRO 2 with LED 10W load
  • Hi
    I’ve installed a Shelly PRO 2 with 10W LED gardenlights as a load.
    Ìssue is when the relay is deactivated, the tension measured at the relay fluctuate from about 50VAC to 220VAC.. so one of the LED spotlight lightup for a second and this by a certain frequence.
    So for me it Seams like the load is to low??
    Anyone has a solution? Or does the Shelly pro 2 has an faulty working?
    Thans you already
