Wall display devices offline if cloud not enabled?
  • All,
    I wanted to replace a hardware thermostat with the wall display in my attick bathroom, since I have quite some Shelly devices there.
    When adding those devices in the wall display, I notice that most of them show as offline (which they are not). However, most devices do not have cloud enabled because I use MQTT functionality, and these devices cannot combine both.
    I have 1 devcie with cloud enabled, and that one shows correctly.
    I hope cloud does not have to be enabled for a device to be useable on the wall display, that would be a complete showstopper. The temperature measurement and plug I want to use as thermostat sensor and output, would also be not useabl then.
    Anyone have similar experience or solution?
  • backkri 28. Dezember 2023 um 22:28
    Hat den Titel des Themas von „Wall display devices offline if cloud not anabled?“ zu „Wall display devices offline if cloud not enabled?“ geändert.
