CORS problem with REST API
  • Hello.
    There is already similar thread, see here. But no conclusion.
    I have Shelly EM device, so this example is related to it.
    Standard request in browser is working normally: http://ip.address/emeter/0 -> Response is some JSON {"power":0.00,"reactive":0.00,...}.
    But when I try to get data from Javscript with this code:
    http_request = new XMLHttpRequest();
    http_request.open('get', 'http://ip.address/emeter/0', true);
    http_request.setRequestHeader('Content-Type', 'application/json');
    http_request.send();
    I will get error response in current Chrome: Access to XMLHttpRequest at 'http://ip.address/emeter/0' from origin 'http://different.ip.address' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
    The reason is that Shelly device will respond just with header Content-Type: application/json, but no Access-Control-Allow-Origin: *. In fact, when I am requesting application/json, there is some "preflight request" from browser to device, which also needs response with access control header...
    Can this be fixed globally, or at least can be added some option to menu?
    Thanks.
  • You can specify a no-cors request if you use the fetch API rather than the XMLHttpRequest object:
    fetch('http://ip.address/emeter/0', {mode: 'no-cors'}).then(resp => {
      console.log(resp)
    Edit:
    Of course, looking into it, while that allows the response to happen, you get an "opaque" response so still can't access the JSON packet in javascript.
    Agreed that adding some headers might fix this, but my understanding from another support request is that space on these devices is tight
    Einmal editiert, zuletzt von jymbob (27. März 2020 um 11:06) aus folgendem Grund: Fuller reply
  • Well, this is problem of a one line in code.
    In case of text/plain in request... That means Shelly needs to add 'Access-Control-Allow-Origin', '*' to response header, thats all. There is no "preflight request".
    In case of data/json in request... There is "preflight request". In Python code, it can looks like this:
    I know, that CORS is pain in the ass, but solution is simple (When You have access to server :-D).
  • I'm having the exact same issue. Did you get any update from Shelly support on the 'Access-Control-Allow-Origin' header?
    jymbob: Did you manage to authenticate using the fetch() command? I'm really strugling with this as well. Everything runs fine as long as I call the API (incl. authentication) through an API client such as Insomnia. But as soon as I call the API through my React app, either with fetch, axios ..., authentication does not work anymore and I get the CORS issues (I can "understand" the CORS issue as the React app is running in the browser).
  • No, the only solution I can suggest is to pass the React call to your own backend somewhere, perform the request there, then forward the response back to your App. Less than ideal
