Connect to Shelly Plug S using MQTT
  • I'm trying to connect to my Shelly Plug S using MQTT. I am using Python client 'Paho' and MQTT broker 'Mosquitto'. I added the Shelly to my adres so it now has ip: 192.168.212.12. I configured my MQTT with a username and password. For the adres field I put '192.168.212.12:1883'. Is this correct?
    I have the Mosquitto broker running on my pc so I guess it is on localhost/127.0.0.1
    When I try to connect using my Python code I get this error:
    [WinError 10061] No connection could be made because the target machine actively refused it.
    The settings in my Shelly look like this:
        "device": {
            "type": "SHPLG-S",
            "mac": "2CF4322670CA",
            "hostname": "shellyplug-s-2670CA",
            "num_outputs": 1,
            "num_meters": 1
        "wifi_ap": {
            "enabled": false,
            "ssid": "shellyplug-s-2670CA",
            "key": ""
        "wifi_sta": {
            "enabled": true,
            "ssid": "Inet24",
            "ipv4_method": "dhcp",
            "ip": null,
            "gw": null,
            "mask": null,
            "dns": null
        "wifi_sta1": {
            "enabled": false,
            "ssid": null,
            "ip": null,
            "gw": null,
            "mask": null,
            "dns": null
        "mqtt": {
            "enable": true,
            "server": "192.168.212.12:1883",
            "user": "simon",
            "id": "shellyplug-s-2670CA",
            "reconnect_timeout_max": 60.000000,
            "reconnect_timeout_min": 2.000000,
            "clean_session": true,
            "keep_alive": 60,
            "max_qos": 0,
            "retain": false,
            "update_period": 30
        "coiot": {
            "update_period": 15
        "sntp": {
            "server": "time.google.com",
            "enabled": true
        "login": {
            "enabled": false,
            "unprotected": false,
            "username": "admin",
            "password": "admin"
        "pin_code": "",
        "name": "",
        "fw": "20200309-104506/v1.6.0@43056d58",
        "discoverable": true,
        "build_info": {
            "build_id": "20200309-104506/v1.6.0@43056d58",
            "build_timestamp": "2020-03-09T10:45:06Z",
            "build_version": "1.0"
        "cloud": {
            "enabled": false,
            "connected": false
        "timezone": "Europe/Amsterdam",
        "lat": 52.370201,
        "lng": 4.895170,
        "tzautodetect": true,
        "tz_utc_offset": 3600,
        "tz_dst": false,
        "tz_dst_auto": true,
        "time": "13:26",
        "unixtime": 1585229213,
        "hwinfo": {
            "hw_revision": "prod-190516",
            "batch_id": 1
        "max_power": 2500,
        "led_status_disable": false,
        "led_power_disable": false,
        "relays": [
                "ison": true,
                "has_timer": false,
                "overpower": false,
                "default_state": "off",
                "auto_on": 0.00,
                "auto_off": 0.00,
                "btn_on_url": null,
                "out_on_url": null,
                "out_off_url": null,
                "schedule": false,
                "schedule_rules": [
                    "1630-01234-off",
                    "0800-01234-on"
                "max_power": 2500
        "meters": [
                "power": 3.84,
                "is_valid": true,
                "timestamp": 1585229213,
                "counters": [
                    4.126,
                    4.227,
                    4.376
                "total": 377
    Is some of this info incorrect or is something else wrong? I hope somebody can help me.
