Shelly Plus 2PM - blinds
  • Hello, I'm new at this kinds of work.
    I was able to to mount the shelly plus 2pm to my blinds so now i can control them through the app.
    There is something wrong with the connection or the configuration on the switch. The switch buttons don't do anything.
    I then removed the shelly and mounted the switch just by itself and everything was working again. Mounting the Shelly once more and I cannot have control through the switch.
    Could this be any config that I am missing?
    So describing what I did:
    N - the wire is connected to other blue wires
    O1 e O2 - the wires go to both blinds engine directions
    L (left) - gets energy from the box. I joined cables to send energy to the blinds in the next room
    L (right) - it is connected to the switch L input
    S1 e S2 - connected to both V (directions) of the switch
    I'll add some printscreens of the configs and the shelly to help.
  • So, I closed the circuit for S1 and nothing happened and then closed the circuit to S2 and the blinds went down. It seems to be my Shelly that is not working well so I will ask for a replacement.
  • In my case all was working but stopped once I flashed esphome firmware. Any idea why wouldnt this work?
