Script HTTP.POST to Shelly Cloud fails
Hinweis für Entwickler
  • Hello,
    I always get following error when trying to send HTTP.POST request:
    Zitat
    Return: {"body":"{\"isok\":false,\"errors\":{\"invalid_header\":\"Unauthorized! Wrong authorization header provided!\",\"invalid_token\":\"The login information is invalid! Please login again!\"}}"
    The curl command that works is:
    curl -X POST https://shelly-xx-eu.shelly.cloud/scene/enable?id=xxx -d "enabled=false&auth_key=xxx"
    I tried several formats, my recent try is:
    what's wrong?
    Many thanks for help!
  • It needs to be URL-encoded, I guess. At least, I couldn't get it to work with JSON. So, modify your request body to ensure your queries are URL-encoded, and update your header content type to "application/x-www-form-urlencoded" as well. Then, it should work.
    If it's not on a Shelly device, you could use OAuth to gain access to your Shelly cloud devices.
    SebMai
    5. Juni 2022 um 20:15
