Advice On Setting Up Scenes / Automation
  • Hello,
    I have purchased a decent quantity of Shelly devices, mainly dimmers and currently wiring up most of my lighting this way.
    Ultimately, what I want to be able to do is program one of the momentary wall switches that normally operates a set of lights, to activate a scene. So for example, if I push and hold the kitchen light switch for 3 seconds it activates a 'bed time scene' (ie. turns off all lights apart from say wall lights in the hall) or push and hold the hall light switch it activates an 'entertaining scene' where all lights come on to programmed brightness levels.
    I have played around with the scenes in the app but find it quite confusing to follow as I think some of the translation to English isn't exactly how a phrase would normally be worded.
    I have also had a look at the 'Actions' section links but this limits you to 5 URLs which obviously isn't much good if I want to activate 20 or 30 devices!
    Thanks
    Hopefully someone can help
    Regards
