Hinweis für Entwickler
  • Hi I am using the following the ble-shelly-btn-gateway-for-other-devices.js script to drive a shelly 2pm plus with cover and I get the following error:
    Calling http://192.168.XX.XX/roller/0?go=open failed ---->(XX are numbers)
    i have tried with the bluettoht gateway on and off and it doesn't work at all.
    if i type this url in the web browser it works. Do you know where the problem could be¿ thanks
    EDIT: Solved: RE: Script für BluMotion, Shelly Plus, Dimmer2
    Einmal editiert, zuletzt von Prrr Pa Pa2 (7. Dezember 2023 um 14:59) aus folgendem Grund: Solved
  • Hello Prrr Pa Pa2,
    Pls post a screen of the full error.
    Just to make sure, did you encounter issues with the official Blu Shelly script from their GitHub and resolve them using the easy call script, or are you experiencing a bug with the easy call script?
    Einmal editiert, zuletzt von _[Deleted]_ (7. Dezember 2023 um 21:29)
  • Hello,
    This script can be used to control one or more Roller at the same time.
    The script must still be adapted for the SHELLY PRO DUAL COVER/SHUTTER PM. The ID must still be specified.
    https://shelly-api-docs.shelly.cloud/gen2/Component…dpoint-rollerid
    Einmal editiert, zuletzt von Viedotraum (8. Dezember 2023 um 20:44)
