Push button, how?
  • Ok, I have to ask again, how can I use the Shelly Pro 1 as a pushbutton on my phone?
    It should release the relais automatically.
    The Input/Output settings does nothing, it's just a placeholder in the settings.
    Also, in the Phone App it has only a caption "Input settings" but in the Shelly web there is a "Set output type" too
    but all the items in it are just another indian names for the same function:
    Set relay type
    - Set Shelly Device to a toggle switch... Act as a flip switch, one state for ON one for OFF
    - Momentary switch. Push for ON, push for OFF
    - "Edge" switch, changes state on every hit.
    This makes no sense for me. All the same.
    Is it possible that I have to reflash with some 3rd party firmware to be able to use it as a pushbutton?
    Can I write a script to achieve the same?
    I'm somewhat disappointed, is the product abandonned?
  • Is it possible that I have to reflash with some 3rd party firmware to be able to use it as a pushbutton?
    That's possible with shelly-firmware too.
    You only have to setup an auto-off -timer. ;)
    In the result you switch the relay on and the timer switch it off after x.x seconds. 8)
  • Heh, how cool is that:
    \o/
    Einmal editiert, zuletzt von Attila Kovacs (28. November 2023 um 18:36)
  • No script, this is a shelly-integrated function since the Shelly1. ;)
