Temperature controlled output
Hinweis für Entwickler
  • Hi
    I got a Plus1PM with the addon, two DS18B20 temperature sensors.
    Is it possible to create a script (running local in the 1PM) controlling the output according to the temperature difference of the two sensors.
    to be used for my hotwater tank
    if t1 > t2+5 the output on else off
    Appreciate your Help
    Einmal editiert, zuletzt von Gribben11 (24. November 2023 um 15:55)
  • Yah thats possible:
    I am not sure, but I think you could do this without a script, just via Web UI actions.
  • You can get the temperature from add-on sensors like this:
    function Loop(){
      try{
          var temp= Shelly.getComponentStatus('Temperature', 101).tC;  //Temp ID, mostly 100 to 102
          print(temp);
      }catch(e){print(e);}
    Timer.set(2000,true,Loop);
    Here are some script examples that use the addon.
    ostfriese
    21. September 2023 um 20:57
    _[Deleted]_
    14. Dezember 2023 um 04:23
    _[Deleted]_
    13. Dezember 2023 um 21:14
    2 Mal editiert, zuletzt von _[Deleted]_ (22. Dezember 2023 um 18:06)
