JSON trouble parsing MQTT.subscribe result
Hinweis für Entwickler
  • I'm trying to flip a switch based on a value I'm reading from my MQTT broker in Shelly script. My starting point was the "mqtt_discovery.js" example and I actually managed to get data read.
    However, the data from the broker (mosqitto) is a JSON string - and that's where my problems start. While I managed to parse manually created JSON strings using JSON.parse(), I keep getting "Uncaught SyntaxError: Expecting a valid value, got EOF".
    Could anybody please help me wrangle the (malformed?) JSON string?
    Script:
    Value in MQTT:
    • plain: {"value": 193.2}
    • string from Debug Log: "{\"value\": 193.2}"
    Weird effect - if I use JSON.stringify() on the value, I get:
    • plain: "{\"value\": 193.2}"
    • string from Debug Log: "\"{\\\"value\\\": 187.6}\""
    Error in debug log:
    < {"ts":1700520635.55< {"ts":1700520985.856, "level":2, "data":"shelly_scripts_rpc.:348 Sending \"script_1.js\""}
    < {"ts":1700520985.869, "level":-1, "data":""}
    < {"ts":1700520985.888, "level":-1, "data":"Uncaught SyntaxError: Expecting a valid value, got EOF"}
    < {"ts":1700520985.891, "level":-1, "data":" at line 1 col 1"}
    < {"ts":1700520985.892, "level":-1, "data":""}
    < {"ts":1700520985.894, "level":-1, "data":"^"}
    < {"ts":1700520985.898, "level":-1, "data":"in function called from system"}
    < {"ts":1700520985.899, "level":-1, "data":""}
    < {"ts":1700520985.905, "level":1, "data":"shelly_user_script.:397 syntax_error: Error in EjsCall"}
    < {"ts":1700520985.935, "level":2, "data":"shelly_notification:163 Status change of script:1: {\"id\":1,\"errors\":[\"syntax_error\"],\"running\":false}"}
  • Hello ParaDogma ,
    The first _msg is an empty string. To fix this error, a string and length check are required, here this should work:
