I have an edge stair switch (see attachment) that I would like to remove and replace with a Shelly Plus 1. I'm not sure how I should wire the brown and two black wires so that the functionality of the other 5 physical switches on this circuit is maintained. Thanks for the help.
How to replace a stair switch with a Shelly Plus 1
- SHELLY PLUS 1
fifinka -
20. November 2023 um 14:01 -
Unerledigt
Dies ist bestimmt ein Schema-Deviator. Suchen Sie im Internet. Es ist wichtig, wie viele Knopfe sich in dem Schema befinden, ich schicke Ihnen einen doppelten Schema-Deviator.
Edit by 66er:
Bild wegen vermutetem Copyrightverstoss gelöscht. -
Hello fifinka,
for the better understanding, you have 6 switches controlling one circuit? In the beginning and the end you have changeover switches, between them cross switches. The shelly must be connected to the last switch (next to the lamp). If you want to remove this switch, you have to change the cross switch connected to this switch against this changeover switch. You need permanent life and neutral there.
fifinka :
Have a look here pleaseDer Inhalt kann nicht angezeigt werden, da er nicht mehr verfügbar ist. -
Here is a little scheme:
