Brand new Shelly Plus Plug S not providing power and energy readings
  • A few weeks ago I bought my first Shelly product being the Plus Plug S. I've integrated the plug in Home Assistant using the standard integration. I noticed that no power and energy readings are shown Home Assistant. So I used the API to see if that would produce the correct values. Unfortunately it doesn't. There is a load connected to the plug, it's clock is synchronized and voltage plus current is displayed correctly. I assume that since P=U*I and energy=P*t, the firmware of the device has to calculate the power and energy values.
    The command http://IP address/rpc/Shelly.GetStatus produces the following output:
    "ble": {},
    "cloud": {
    "connected": false
    "mqtt": {
    "connected": false
    "plugs_ui": {},
    "switch:0": {
    "id": 0,
    "source": "button",
    "output": true,
    "apower": 0,
    "voltage": 236.6,
    "current": 0.29,
    "aenergy": {
    "total": 0,
    "by_minute": [
    0,
    0,
    0
    "minute_ts": 1700390751
    "temperature": {
    "tC": 34.3,
    "tF": 93.7
    "sys": {
    "mac": "3CE90E2FD284",
    "restart_required": false,
    "time": "11:45",
    "unixtime": 1700390753,
    "uptime": 160227,
    "ram_size": 246160,
    "ram_free": 144876,
    "fs_size": 458752,
    "fs_free": 139264,
    "cfg_rev": 38,
    "kvs_rev": 3,
    "schedule_rev": 0,
    "webhook_rev": 0,
    "available_updates": {
    "stable": {
    "version": "1.0.8"
    "wifi": {
    "sta_ip": "IP address",
    "status": "got ip",
    "ssid": "XXXXXXXXX",
    "rssi": -74
    "ws": {
    "connected": false
    May I assume that "apower" corresponds with the power value in W?
    That "aenergy" corresponds to the Wh of kWh?
    Any idea why "apower" shows 0?
    Any idea why "aenergy" is 0?
    Einmal editiert, zuletzt von HAUser@NL (26. November 2023 um 10:17)
