Shelly BLU motion triggering Shelly Plus Plug S - without cloud ?
  • Note: this question is about Shelly BLU motion, but the forum tag does not include that product. So i choose Shelly Motion 2 there.
    Question:
    I have managed to set up a Shelly BLU motion to trigger a Shelly Plus Plug S by configuring appropriate Scenes to switch the Plug on/off.
    But this all requires the cloud. I would like a solution that works directly without cloud.
    I also do not want this to require a home controller like Home Asssistant, but directly from BLU motion triggering the Plus Plug S.
    I can do direct triggering without need for a controller or cloud from any Shelly WiFi switches for example to any Shelly Relay or Plug (have that running for a range of lighting). But i wanted the BLU motion for longer battery life and smaller size (i guess it would work with Shelly Motion 2, but i have not bought one).
    Other lower-than-wifi power solutions like Z-Wave or HomeMatic IP also support that direct coupling.
    Thanks for any information!
  • You can send commands directly to any URL. Thus, you can trigger your Plug S directly that way without the need for a cloud.
    25+ Shelly Mini1G3 etc. im Außenbereich & Garage, KNX im Haus, Edomi & Home Assistant für Automatisierung und Visu
  • I don't have the BLU motion, but I use the Door & Window sensor.
    You access the sensors thru the Shelly BLU gateway, on which you can also run scripts. Unfortunately, with FW 1.0.8 you cannot access the scripts via the Web GUI but have to use the app instead, which is a p* in the b*.
  • Here is a link to some commands you can use to trigger the Plug S: Plug S URL Action Commands
    I am currently on the road, but will see later if I can test this myself in my setup with my Plug S and BLU D&W.
