Shelly dimmer 2 getting disconnected from wifi
  • Hi everyone..
    Have issue with one of dimmers . It started dropping out of network .. first time it happened it came back online after power cycling. and it was fine for few months.. after that it started happening once a week.. then couple of times per week.. and as of few days it will drop after only hour or so.. .. In the same location i have two other dimmers (its a 3 gang switch plate) and other two are working fine. It does respond when using a switch (turns lights on/off and dimms)
    On my search i came across shelly 2.5 with capacitor issue.. where it would be dropping out of wifi.. which is exactly the same issue i'm having
    could dimmer 2 have same capacitor problem???
    I did try firmware updates / flushed several times.. even factory reset.. no fix...
    any help would be appreciated
