[Shelly Plus 2PM] Can't change the Device Profile to Cover
  • Hi,
    i've noticed a bug in the current Cloud UI web interface.
    v3.36.9
    While changing Shelly Plus 2PM (20231106-160229/1.0.8-gdba0ee3) device profile to "cover" to control the Rolling Window Shutters/Blinds, i got an error notification "Failed to apply settings".
    Further investigation has revealed the following network response error: Missing required argument 'name'!
    I've tried to set the Device Name in the corresponding settings menu, and it failed with the same error. I did also replay the request with a modified payload containing the name parameter, but it failed too.
    The workaround to make it work is to connect to the Shelly Plus 2PM web interface using the allocated IP address, and there it is possible.
    Hoping for a rather straightforward fix in the next version.
    Thank you
  • Hello,
    I have the same issue with some of my Shellys 2PM. Is there a planning for a bug fix? Why are not all Shelly 2PMs affected?
    Thank you for your support.
    Simon
  • The problem was fixed on the same day on November 15th. Are you sure this is the same problem? Is your app version up to date? Check for updates in the Play or Apple Store
