Shelly.call ("HTTP.GET" Or ("HTTP.POST"
Hinweis für Entwickler
  • Roberto Grosso 13. November 2023 um 18:27
    Hat den Titel des Themas von „Shelly.call("HTTP.GET" Or "HTTP.POST"“ zu „Shelly.call ("HTTP.GET" Or ("HTTP.POST"“ geändert.
  • Hallo Roberto,
    if you have a question solely regarding HTTP GET and POST, please provide your HTTP POST request along with the log detailing the result of the call and the exact issue.
    1. function onButtonPress_1(BTHparsed) {
    2.   if (Event254 === false) {
    3. Shelly.call("HTTP.POST",
    4.         { url: url_cmd_00 },
    5.         null,
    6.         null
    7.       );
    8.     }
    9. Event254 = false;
    10. cnt1++;
    11. KVSStore("Cnt_01",cnt1);
    12.     }
    the above function just do nothing
    the below work
    3. Shelly.call("HTTP.GET",
    5.         null,
    6.         null
    7.       );
    8.     }
    10. cnt1++;
    12.     }
  • You are missing a Body in your post call:
    First of all, what is post used for? Its main use is to send/post your own data to xy.
    And what is get used for? To get data or just to call a url without sending data to it.
    There is also http. Request, which is the more advanced way to do complex http stuff.
    More infos about this:
    https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/HTTP/
    Einmal editiert, zuletzt von _[Deleted]_ (15. November 2023 um 23:38)
