Well, just found out that there is a limit of 5 RPC calls per script. I have 10 bulbs that I would like to turn on after I push one of the WS4 buttons that is connected to i4. Is there any workaround for that? There is this limitation for action as well but I can create multiple actions. I could create multiple scripts but that might be hard to maintain/adjust...
Too many calls in progress
Hinweis für Entwickler
Here this script handels up to 40 activ calls:
In this script, just use Call() instead of Shelly.call() handeling the right amout of calls will be done by the toolbox part.
Alles anzeigenfunction Event_Trigger(data){ let input0= Efilter(data,{device:['input:0'],filterValue:['single_push']}); let input1= Efilter(data,{device:['input:1'],filterValue:['single_push']}); if(input0) Switch_RGB('on'); if(input1) Switch_RGB('off'); } function Switch_RGB(turn){ Call('HTTP.get',{url: 'http://192.168.178.51/white/1?turn='+turn, timeout: 1}); Call('HTTP.get',{url: 'http://192.168.178.51/white/0?turn='+turn, timeout: 1}); Call('HTTP.get',{url: 'http://192.168.178.11/white/3?turn='+turn, timeout: 1}); Call('HTTP.get',{url: 'http://192.168.178.11/white/2?turn='+turn, timeout: 1}); Call('HTTP.get',{url: 'http://192.168.178.11/white/1?turn='+turn, timeout: 1}); Call('HTTP.get',{url: 'http://192.168.178.11/white/0?turn='+turn, timeout: 1}); } function Main(){ Shelly.addEventHandler(Event_Trigger); } //Dekats Toolbox, a universal Toolbox for Shelly scripts function Blink(bc,dl,c,st){//Call Blink funktion, bc=blinkCount, dl=blinkDelay, c=call->as_arry->[methode,parameter], st=startCount try{ if(tH8) Timer.clear(tH8); tH8= 0; if(!Str(st)) st= 0; if(st < bc*2){st++;}else{st= 0; return;} if(!tH8) tH8= Timer.set(1000*dl,0,function(){Call(c[0],c[1],function(){tH8= 0; Blink(bc,dl,c,st);},c[3],c[4]);}); }catch(e){ErrorMsg(e,'Blink()');}} function SwitchM(cID,rM,iT,deBug){ //Change rM=RelayMode, iT=InputMode, cID=Relay_ID and/or Input_ID, try{ //More Info, rM='detached'->detached/flip/momentary/follow,iT='switch'->button/switch let r= 0; if(Config('switch',cID).initial_state === 'match_input') Call('Switch.SetConfig',{id:cID,config:{initial_state:'restore_last'}}); if(rM && Config('switch',cID).in_mode !== rM){Call('Switch.SetConfig',{id:cID,config:{in_mode: rM}});if(!r){r= '';} r+='rM, ';} if(iT && Config('input',cID).type !== iT){Call('Input.SetConfig',{id:cID,config:{type: iT}});if(!r){r= '';} r+='iT, ';} if(deBug){r='Debug: tryed to change-> '+(r||'nothing,')+' Oldconfig: rM-> '+Config('switch',cID).in_mode+', iT-> '+Config('input',cID).type; print(r);} return r;}catch(e){ErrorMsg(e,'SwitchM()');}} function Str(d){ //Upgrade JSON.stringify try{ if(d === null || d === undefined) return null; if(typeof d === 'string')return d; return JSON.stringify(d);}catch(e){ErrorMsg(e,'Str()');}} function Cut(f,k,o,i){ //Upgrade slice f=fullData, k=key-> where to cut, o=offset->offset behind key, i=invertCut try{ let s= f.indexOf(k); if(s === -1) return; if(o) s= s+o.length || s+o; if(i) return f.slice(0,s); return f.slice(s);}catch(e){ErrorMsg(e,'Cut()');}} function Efilter(d,p,deBug) { //Event Filter, d=eventdata, p={device:[], filterKey:[], filterValue:[], noInfo:true, inData:true}->optional_parameter try{ let fR= {}; if(p.noInfo){fR= d; d= {}; d.info= fR; fR= {};} if(p.inData && d.info.data){d.info= d.info.data; delete d.info.data;} if(!d.info) fR.useless= true; if(p.device.length > 0 && p.device.indexOf(d.info.component) === -1) fR.useless= true; if(p.filterKey && !fR.useless) for(f of p.filterKey) for(k in d.info) if(f === k) fR[k]= d.info[k]; if(p.filterValue && !fR.useless) for(f of p.filterValue) for(v of d.info) if(Str(v) && f === v) fR[Str(v)]= v; if(deBug) print('\nDebug: EventData-> ', d, '\n\nDebug: Result-> ', fR, '\n'); if(Str(fR) === '{}' || fR.useless){return;} return fR;}catch(e){ErrorMsg(e,'Efilter()');}} function ErrorChk(r,e,m,d){ //Shelly.call error check try{ aC--; if(aC<0) aC= 0; if(d.CB && d.uD) d.CB(r,d.uD); if(d.CB && !d.uD) d.CB(r); if(!d.CB && d.uD) print('Debug: ',d.uD); if(e) throw new Error(Str(m)); if(Str(r) && Str(r.code) && r.code !== 200) throw new Error(Str(r)); }catch(e){ErrorMsg(e,'ErrorChk(), call Answer');}} function Cqueue(){ //Shelly.call queue try{ if(!cCache[0] && !nCall[0]) return; if(!nCall[0]){nCall= cCache[0]; cCache.splice(0,1);} if(nCall[0] && aC < callLimit){Call(nCall[0],nCall[1],nCall[2],nCall[3],nCall[4]); nCall= [];} if((nCall[0] || cCache[0]) && !tH7) tH7= Timer.set(1000*cSp,0,function(){tH7= 0; Cqueue();});}catch(e){ErrorMsg(e,'Cqueue()');}} function Call(m,p,CB,uD,deBug){ //Upgrade Shelly.call try{ let d= {}; if(deBug) print('Debug: calling:',m,p); if(CB) d.CB= CB; if(Str(uD)) d.uD= uD; if(!m && CB){CB(uD); return;} if(aC < callLimit){aC++; Shelly.call(m,p,ErrorChk,d);}else if(cCache.length < cacheLimit){ cCache.push([m,p,CB,uD,deBug]); if(deBug) print('Debug: save call:',m,p,', call queue now:',cCache.length); Cqueue(); }else{throw new Error('to many Calls in use, droping call: '+Str(m)+', '+Str(p));}}catch(e){ErrorMsg(e,'Call()');}} function Setup(l){ //Wating 2sek, to avoid a Shelly FW Bug try{ if(Main && !tH9){ tH9= Timer.set(2000,l,function(){print('Status: started Script _[', scriptN,']_'); if(callLimit > 5){callLimit= 5;} try{Main();}catch(e){ErrorMsg(e,'Main()'); Setup();}});}}catch(e){ErrorMsg(e,'Setup()');}} function ErrorMsg(e,s){ //Toolbox formatted Error Msg try{ let i= 0; if(Cut(e.message, '-104: Timed out')) i= 'wrong URL or device may be offline'; if(s === 'Main()') i= e.stack; if(Cut(e.message, '"Main" is not')) i= 'define a Main() function before using Setup()'; print('Error:',s || "",'---> ',e.type,e.message); if(i) print('Info: maybe -->',i);}catch(e){print('Error: ErrorMsg() --->',e);}} var tH7= 0, tH8= 0, tH9= 0, aC= 0, cCache= [], nCall= [], callLimit= 5, cacheLimit= 40, cSp= 0.2; //Toolbox global variable var Status= Shelly.getComponentStatus, Config= Shelly.getComponentConfig; //Renamed native function var info= Shelly.getDeviceInfo(), scriptID= Shelly.getCurrentScriptId(), scriptN= Config('script',scriptID).name; //Pseudo const, variabel //Toolbox v2.0-Alpha(full), Shelly FW >1.0.2 Setup(); -
Yes, that works perfectly. Big thanks!!
