Shelly 1PM switch temperature turn on switch
Hinweis für Entwickler
  • I'm brand new at this... I've been scouring the forum.
    I'd like to turn on the power to some fans if the switch temp hits a certain value. Using IP/rpc/Shelly.GetStatus I see that "temperature": {tC":47.3, "tF";117.1}.
    So I assume a script such as;
    switch.temperature.tC > 35 = turnon switch
    Or some such verbage. I have no programming knowledge... stumbling through this. Any hints are welcome!
  • Hi dannoz ,
    thats easy to do, here try this Script:
    2 Mal editiert, zuletzt von _[Deleted]_ (11. November 2023 um 00:53)
  • As I'm decifering this... at 35C the switch turns on. I don't clearly see a section turning off the switch if the temp falls below 35. Do I need to add;
    function CheckTmp(d){
    try{
    let _name= Cut(device,':',0,true);
    let _id= Number(Cut(device,':',1));
    let aTmp= Status(_name,_id).temperature[tmpType];
    let output= Status(_name,_id).output;
    if(debug) print('Debug: name:',_name,', id:',_id,', aTmp:',aTmp,', output:',output);
    if(aTmp >= tmpLimit && !output) Call('Switch.set',{id: _id, on: true},null,null,debug);
    if(aTmp < tmpLimit && !output) Call('Switch.set',{id: _id, on: false},null,null,debug);
    }catch(e){ErrorMsg(e,'CheckTmp()');}
  • Hmmm, that's a good point. I forgot to turn the device back off. :D
    But to be fair, you never mentioned turning it off again in your request.
    Einmal editiert, zuletzt von _[Deleted]_ (11. November 2023 um 19:20)
