Timezone Europe/Amsterdam not available in list (firmware 1.0.8)
  • I just received my 4th Plus Plug S V2. Updated directly to 1.0.8. I can't set the timezone in the locations settings; Europe/Amsterdam is not available. Also the auto detect function does not work.
    The other 3 plugs are also on 1.0.8 and do show Europe/Amsterdam as timezone and also the auto detect works. Only difference is that I did the initial install on them on 1.0.7.
    Already tried factory resetting the 4th one a few times, but still does not work. Any clue what is going on. Bug in 1.0.8?
    Left one of the 3 old ones, right the new one.
    http://api.shelly.cloud/timezone/autodetect does work if I put it in my broswer (also works on the other 3 plugs):
    {"isok":true,"data":{"ip":"24.132.103.120","time_zone":"Europe\/Amsterdam","latitude":
    Log also seems fine.
    shelly_http_client.:306 0x3ffdf52c: HTTP GET http://api.shelly.cloud/timezone/autodetect 23:02:47
    shelly_http_client.:606 0x3ffdf52c: Finished; bytes 748, code 200, redir 0/3, auth 0, status OK 23:02:47
    So the problem appears to be that this timezone simply isn't in the list?
