Shelly Duo - RGBW E27 appears to reset itself after some days off
  • I've a "Shelly Duo - RGBW E27" bulb, that is not used very often. It may stay switched off for several days or even a couple of weeks.
    The bulb uses to be set to light as White (4750K), although when I light it after several days off it uses to lit in blue and always remains offline at Shelly app. It looks like that at some point in time the bulb did reset itself.
    To overcome the situation I need to add it again via WiFi, as if it was a new device, and redo at least some of the configurations (e.g. the color).
    Anyone with the same problem?
    Any advice?
    Fernando
  • What firmware is installed on the Shelly DUO? latest 1.14.0?
    @Olsche Do you have some news about the issue? I have the same problems 2 times within 2 days. The error seems to be the firmware. You can't enable or disable the "factory_reset_enable_from_switch" button. when will it be fixed? Thank you in advance
