Motion 2 - Cloud not connecting when static IP set
  • Hello,
    I installed a Motion 2 and all was perfect for a week or more. Once I had proved it would do what I needed I then changed it to static IP, as recommended for the battery devices.
    Since then it is shown as Offline in the app and at control.shelly.cloud
    I can still access it on the lan using a browser.
    Any solutions would be much appreciated.
    Thanks for reading.
    UPDATE:
    I tried to re-add using the app on my phone, using its IP. The result was a message that it's already owned by another user account. I then deleted the original (showing as offline) device and tried again. This worked but it constantly states 'pending connection', and the control.shelly.cloud shows it as offline.
    In case that helps with the diagnosis!
    I have to say that I have found the adoption of devices across the Shelly range to be pretty much 100% frustrating since I started using them, years ago. Once they're set up they're rock solid. But the initial stage is always massively, unnecessarily, complicated
    2 Mal editiert, zuletzt von N20net (7. November 2023 um 17:41)
