Shelly Wall display 1.2.4 - released! & NEWS
    How to switch off the screen:
    https://youtu.be/oSQIqxIkiIo
    Source: englisch FB-Group
  • If you are adding the Wall Display Thermostat to a room is the procedure different than when adding a standard thermostat
    Open Room Highlight Thermostat, add Thermostat, give it a name, select room, Choose thermostat type, Select device (Wall Display), Choose sensor the sensor in the wall display it not an option you can select.
    Alternative Open Wall display web interface, Select Temperature, Actions, Event Temperature in Celsius Change (Threshold Condition) Les Than 22 degrees, Then Control output on, Hit Url http://192.168.1.xxx/relay/0?turn=on
    When Temperature goes above or below set amount it doesn't hit the Url A small red line is visible see attached pictures from
    web interface.
    it does not control the onboards relay
    Which Is the correct way to set this Wall Display to work as a thermostat
    I have tried Firmware 1.2.4 and Beta 1.2.5 both give the same results.
    Regards
    Pierce
  • Which Is the correct way to set this Wall Display to work as a thermostat
    With FW 1.2.5-beta7 there is the test version with the correct thermostat function. No detour with a virtual thermostat.
    Install FW 1.2.5-beta7 via the WEB UI, swipe all the way to the left to the settings menu and activate the thermostat function there.
    You will then find the thermostat settings on the 1st page to the right of the dashboard.
