Shelly 1 PM random factory reset
  • Hi everyone,
    I have a problem with one Shelly 1pm .
    Specifically, the device randomly performs a factory reset and then disconnects from my account.
    When I try to add it back to my account randomly after 1/2 hours it does a factory reset again.
    And then I have to add it back to my account.
    There is a way to solve this problem?
    below are some logs:
    2697586172 cloud_aes.c:576 free mem: 30776 / 23176, buf len: 176, buf size: 190
    12697596626 cloud_aes.c:406 Bytes written: 176 bytes remaining: 0
    12697669620 cloud_common.c:1173 Cmd: status
    12697674542 cloud_common.c:144 Confirmed status serial 277
    12697680281 cloud_common.c:1176 Cloud clear status timer
    12697687034 cloud_aes.c:592 Sending 31 bytes
    12697691294
    12697697335 cloud_aes.c:576 free mem: 30708 / 23176, buf len: 32, buf size: 46
    12697705726 cloud_aes.c:406 Bytes written: 32 bytes remaining: 0
    12721308711 shelly_sntp.c:441 minute tick at 23:59:00
    12738534958 switch1pm.c:952 Factory reset
    12738539811 shelly.c:233 ERASING CONFIGURATION TO FACTORY DEFAULTS
    12738865816 mgos_sys_config.c:323 Saved to conf9.json
    12738883687 shelly_actions.c:271 Remove file: actions_btn_on_url_0
    12738898658 shelly_actions.c:271 Remove file: actions_btn_off_url_0
    12738913636 shelly_actions.c:271 Remove file: actions_longpush_url_0
    12738928652 shelly_actions.c:271 Remove file: actions_shortpush_url_0
    12738944705 shelly_actions.c:271 Remove file: actions_out_on_url_0
    12738959678 shelly_actions.c:271 Remove file: actions_out_off_url_0
    12738974655 shelly_actions.c:271 Remove file: actions_lp_on_url_0
    12738990649 shelly_actions.c:271 Remove file: actions_lp_off_url_0
    12739040856 shelly_actions.c:271 Remove file: actions_report_url_0
    12739055801 shelly_actions.c:271 Remove file: actions_report_url_1
    12739070748 shelly_actions.c:271 Remove file: actions_report_url_2
    12739086726 shelly_actions.c:271 Remove file: actions_ext_temp_over_url_0
    12739101673 shelly_actions.c:271 Remove file: actions_ext_temp_under_url_0
    12739116615 shelly_actions.c:271 Remove file: actions_ext_temp_over_url_1
    12739132633 shelly_actions.c:271 Remove file: actions_ext_temp_under_url_1
    12739147576 shelly_actions.c:271 Remove file: actions_ext_temp_over_url_2
    12739162525 shelly_actions.c:271 Remove file: actions_ext_temp_under_url_2
    12739178564 shelly_actions.c:271 Remove file: actions_ext_hum_over_url_0
    12739195890 shelly_actions.c:271 Remove file: actions_ext_hum_under_url_0
    12739256418 mgos_sys_config.c:353 Removed conf9.json
    12739261376 shelly_util.c:344 RF Start address 1fb000 4096
    12739267253 mgos_system.c:58 Rebooting in 500 ms
    12739723169 esp_main.c:138 SDK: state: 5 -> 0 (0)
    12739728841 esp_main.c:138 SDK: rm 0
    12739734044 esp_main.c:138 SDK: pm close 7
    12739745681 cloud_aes.c:432 Cloud connection 0x3fff3fac closed
    12739750455 cloud_common.c:1612 Stop status keep alive timer
    12739755945 cloud_aes.c:139 Reconnect after 1000
    12739763804 mgos_wifi.c:70 WiFi STA: Disconnected, reason: 8
    12739817718 esp_main.c:138 SDK: sleep enable,type: 2
    Thank you
    regards
    Lorix
