Control of own Power Plant Energy with Shelly App (new HELPER function for addition/subtraction for scenes)
Hinweis für Entwickler
  • Hi Shelly Team & Forum members,
    the shelly app is missing a subtraction/addition helper function for energy scenes. I have the following use case (problem):
    - I have the Shelly Pro3EM to measure the negative grid power of my solar energy plant (energy I sent back to my energy supplier but want to use it by myself)
    - I want to buy the Shelly Dimmer 0-10V (as input signal for a heating controller - industry standard 0-10V controls)
    - I have the Shelly PM connected to the Heater plug for my warm water boiler to measure the heater power consumption.
    Problem: I can add a scene with an action if 3EM has a certain value. Example: If the negative grid power is smaller than -500W then put the dimmer to 50%. But this does not consider that the dimmer (or heater ShellyPM) is already ON with e.g. 30% = 300W.
    Solution/Required Scene (addition/subtraction - new HELPER value function):
    Part1: Helper1 [W] (in my case new Heater/Dimmer value) = Shelly pro3EM [W] - ShellyPM [W]
    Result: Helper1 = -500W - 300W = -800W
    Part2: Scene: IF Helper1 [W] =< -800W then set Dimmer to 80%
    I believe this small Helper function would bring you a lot of new paying customers for the new app. I know this could also be done with home assistant but more complex (I am not HA expert) :-)
  • Hello Hartmutra,
    I have the same problem, could you please let me know if you will have some answer. Thank you.
    Hello mkratas,
    Sure, I will let you know (hopefully I get an answer). If The Shelly APP would be able to calculate you could safe a lot of effort (e.g. buy a RasPi4, Install Home Assistant, learn Yaml programming)....
    WbR
    Hartmut
