Scripting Question with Shelly.call()
  • If I run the following script, everything works fine. (basically pulled from https://github.com/shelly-tools/s…_consumption.js)
    But if I enable the switching of the device(Shelly.call), it will not respond anymore.
    I found a couple of advices, but I guess I don't interpret them correctly.
    link
    i am running the code on a "pro 3" with Version: 0.10.2-beta2
    can someone point me to where I should have a look?
    2 Mal editiert, zuletzt von subbamaggus (19. Oktober 2023 um 08:10) aus folgendem Grund: it was late ;-)
  • this seems to work.
    so nesting is not a good idea.
    i will try to work on that.
    the json looks like:
    3 Mal editiert, zuletzt von subbamaggus (20. Oktober 2023 um 08:24)
  • so.
    i got my script running.
    for all of you who are interested... the script is supposed to read from a hichi (volkszaehler) wifi device. get the current powerflow and then decides to enable a heating element (3 Phases)
    Since i dont have a hichi yet. i tested with a regular json.
    the solution is meant to be stand alone without any other home technology like openhab/iobroker/...
    not finished yet. but the basic functionality is working.
