change long push time
Hinweis für Entwickler
  • Hello ilio1994,
    you could set your Shelly to "detached" and then use timestamps to create custom push events.
    I saw a script for this somewhere on the forum but can't remember where. Nevertheless, it's not difficult to do, so you can just create your own version.
  • Code
    Thanks for the reply. I found this online but it doesn't work but I don't know too much about scripts either. do you think it could work? Maybe there's just some syntax error.
  • This looks like some Chat gpt bullshit, there is no way this could work with a timer, just use timestamps.
    I will try to create a new script for this over the weekend, but it would be better if you could at least give it a try yourself.
    2 Mal editiert, zuletzt von _[Deleted]_ (19. Oktober 2023 um 22:49)
