Disconnect digital inputs from controlling outputs
  • Hi all. I would like to use the Shelly Uni in controlling my 2x garage doors (open/close) but also detect whether they are open? To do this, I use the 2x digital inputs to read the state (magnetic switch when closed connected to digital input). The open/close I trigger using the outputs by connecting these to an external relay board.
    The control works well and I can read the input, but when the magnetic switch on input closes, the output is triggered to open the door!
    Can the digitial inputs be disconnected from controlling the outputs?
    Thanks
  • Ok, I managed to resolve this. On the app-settings, under button type, I had to set this to "Detached Switch - Set this_relays to be in "Detached" switch mode - switch is seperated from the relays"
  • Which garage door motors did you make smart?
    I have 3 garages to upgrade at some point and wanted to add exactly the same magnetic detection using the add-on board.
